Engine alarm Help >
Engine alarm Help
Engine alarm Help
Old 10-16-2015 | 08:06 AM
Default Engine alarm Help
02 Baja 25, Outlaw---brand new 502 engine---engine alarm sending units all brand new---engine alarm rings so to find out what sending unit it was, I pulled the wires off all ---- the sending units one at a time---and the alarm still rings???? All 3 sending units are disconnected ---water temp-oil pressure--and drive fluid bottle----How is the alarm still ringing---could the alarm itself be no good--it is original !!!! Thanks---Mike-Tampa Bay
1stoutlaw is offline
Old 10-16-2015 | 08:33 AM
F-2 Speedy's Avatar
this is a carb'd engine ?
F-2 Speedy is offline
Old 10-16-2015 | 09:52 AM
YES--sorry carbed engine no other electronic sensors
Old 10-16-2015 | 09:57 AM
F-2 Speedy's Avatar
what is the cadence of the beep, solid tone, interrupted ?? two shorts and a long lol
Old 10-16-2015 | 10:04 AM
hmmmn--solid ringing!!!! ????? would it matter w/ all the sending units un-plugged OR do you think I had to much beer and it was stereo noise hahaha!!!!
Old 10-16-2015 | 10:05 AM
97FASTech's Avatar
Veteran: Army
Solid tone / ringing while unstarted? or started?
97FASTech is offline
Old 10-16-2015 | 10:09 AM
F-2 Speedy's Avatar
if you have solid tone unstarted, Im leanin towards the beer, that's normal................you running a knock sensor ?
Old 10-16-2015 | 10:12 AM
When you turn the key on the ringing starts and when the engine starts she goes off-------now stays on (ringing) w/the engine running----oil pressure gauge shows 50 lbs-where she always is and of course the water is cool because the engine was just started......Thanks.......
Old 10-16-2015 | 10:13 AM
No knock sensor------
Old 10-16-2015 | 10:21 AM
F-2 Speedy's Avatar
did it ever work correctly with the new engine, we need more specifics ......
