Mirage Plus Hole Shot >
Old 10-18-2015 | 04:11 AM
Default Mirage Plus Hole Shot
Can anyone help me here please.
I am running a handed pair of Mirage Plus 25" pitch props on Bravo 1 drive with an "X" -2" at 31" centres.
The engines are new 383ci based on new Dart blocks and heads.
All forged internals, stainless steel marine exhausts, Comp Hydraulic roller cams with a compression of 9.1 :1 plus 750 cfm Holley marine carbs.
Cam peak is 5500 rpm
Here is the issue.
With Spinelli over hub 3 blade 14 x 26" cleavers at 5800 RPM = 71.5 mph and easy out of the hole.
With Mirage plus 25" pitch 5100 RPM 75 MPH but beyond painful to come out of the hole.
Can Mirage Plus props be made to perform out of the hole with a high "X" diamention please and if so how ?
Many thanks
Kalaazar
Kalaazar is offline
Old 10-26-2015 | 12:46 AM
I would try some 23 Mirage Plus props. They should spin about 400rpms faster to your 5500rpms and come out of the hole better.
Top speed should stay about the same with the 2" pitch decrease and 400 rpm increase.
Griff is offline
Old 10-27-2015 | 02:46 AM
Appreciated, thanks.
Kalaazar is offline
Old 10-27-2015 | 05:26 PM
Try what Griff said and also call BBlades for their input.
http://bblades.com/
Holy Smokes is offline
Old 11-15-2015 | 04:55 PM
What's your prop shaft height ?
01scarab29 is offline
Old 11-16-2015 | 01:59 AM
My Bravo drives are 2.5" up on the X dim.
Kalaazar is offline
Old 11-16-2015 | 02:00 AM
Many thanks for your input, appreciated.
Kalaazar is offline
Old 11-16-2015 | 07:50 PM
I'm not up on X dim. but I have done a lot of trial and error the past few months. with prop shaft parallel to bottom of boat, how many inches bellow or above is the prop shaft from bottom of boat. I have learned on 3 blade props they shouldn't pierce the water surface. Are you twin engines with V hull
Old 11-19-2015 | 04:55 PM
Hi, I will measure the shaft height from the bottom of the hull this weekend. This is a twin Bravo 1 installation in a Magnum27 Sport.
To date the very best overall propeller performance is with a pair of Spinneli 3 Blade outboard cleavers.
These are very easy to plane out, fair top speed, but have a high slip percentage and a few to many revs. Size 14" x 26" 1.5 : 1. 5850RPM = 71/72 MPH every day.
Kalaazar is offline
Old 11-21-2015 | 03:15 PM
My propeller shafts are 5" to the centre below the bottom of the hull on the drive fore and aft centre line.
Kalaazar is offline
