docking
Old 10-18-2015 | 07:31 PM
docking
hey guys, I had a 32 sunsation the props spun out. I could darn near zero turn one forward one reverse, easy to dock. Just got a 38 donzi the props spin in. It is all over the place i can't control it. Please any sugestions. Thanks
kevin murphy is offline
Old 10-18-2015 | 07:39 PM
Spinning IN, you lose reverse thrust. I noticed it immediatly when I switched mine to IN and tried backing off trailer.
Try lifting your drives a lil above neutral, it should get the thrust below the boat instead of hitting transom.
nailit is offline
Old 10-18-2015 | 07:46 PM
14 apache's Avatar
Make sure you trim the drives up or most of the water will hit the transom. It happened to me when the drives where trimmed down,
14 apache is offline
Old 10-18-2015 | 07:49 PM
seafordguy's Avatar
Where are you from? I know someone with that name in my area, but imagine its coincidence.
seafordguy is offline
Old 10-18-2015 | 08:01 PM
A little bump of the throttle and wheel input goes a long way. I have a lot of hours docking a 38 donzi, gets easier.
If you want the transom to go to starboard turn right, port reverse, stbd forward and use a little port throttle. Trimming drives slightly above neutral helps also.
Unlimited jd is offline
Old 10-18-2015 | 08:36 PM
Michigan
we are about in the middle of the state
Old 10-18-2015 | 08:47 PM
Thanks , when you say above neutral, drives up 1/4 ish? I can't wait to try. We only spent one weekend and had to pull it fof the season. I felt like a jerk trying to dock it.
Old 10-19-2015 | 12:23 AM
Sydwayz's Avatar
Forum Regulator
What size/model Donzi is it? Is it a staggered setup or side by side?
Sydwayz is offline
Old 10-19-2015 | 06:06 AM
rak rua's Avatar
Spot on, you've nailed it.
Lots of trim, especially if it's a notched transom. The wash from the reverse prop just hits the notch and pushes the boat forward. Have a look when it's out of the water and imagine a line from the prop shaft showing where the thrust is aimed. Trim your engine up until that line goes under the transom or notch.
A little steering in the direction of the turn also helps but remember to straighten her up after!
RR
rak rua is offline
Old 10-19-2015 | 06:53 AM
Kevin, when did you get your boat, do you boat on Saginaw Bay? Chris
Feverz29 is offline
