Locate a PROPSHAFT DYNO in Midwest??? >
Old 10-19-2015 | 08:57 AM
Default Locate a PROPSHAFT DYNO in Midwest???
I live in St. Louis but will travel. Trying to solve an ongoing issue that shows its face with engines in boat that's been ongoing for 3+ years . Any references would be much appreciated!
Eliminated572 is offline
Old 10-19-2015 | 09:05 AM
Sounds like a good way to break a drive
JRider is offline
Old 10-19-2015 | 09:11 AM
Lets hope not. I don't need to run the piss out of it to find what I'm looking for. But this will save months worth of water testing.... maybe longer :/
Old 10-19-2015 | 10:01 AM
SB
Give this company a call and see whom may own one in your area:
http://www.dynomitedynamometer.com/p...arine-dyno.htm
SB is online now
Old 10-19-2015 | 10:06 AM
You might try Grand Sport Center in Illinois, I think they hooked my buddies boat up to one there when he bought it.
BIGSLOW is offline
Old 10-19-2015 | 12:17 PM
Mel Riggs, Riggs marine in Wisconsin has a prop shaft dyno.
Bawana is offline
Old 10-19-2015 | 12:25 PM
Make sure the dyno setup has a large enough water supply for the motor.
kvogt is offline
Old 10-19-2015 | 12:44 PM
articfriends's Avatar
what would be unltimately cool would be a in boat dyno that has a shaft that goes directly into the coupler
articfriends is offline
Old 10-19-2015 | 01:12 PM
I always wondered why nobody took a propshaft type dyno and modified it to slide through into the gimbal/coupler once you pulled the drive off.
Gimme Fuel is offline
Old 10-19-2015 | 01:17 PM
MER Performance's Avatar
Sounds like a project for you Steve, I care not to remove my dyno cell and make it portable.....
MER Performance is offline
