Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Rebuilding bolsters with something other then wood >
Old 10-20-2015 | 07:16 PM
Default Rebuilding bolsters with something other then wood
Hello I have a question for the group . I need to rebuild my seat bolsters the wood is coming apart . I would like to use some kind of composite material . But I am not sure what to use . I must support the weight of a person and be able to attach the vinyl to . Any ideas thanks
switchbackman is offline
Old 10-23-2015 | 04:00 PM
I used half inch starboard. Glueing is an issue it is a complicated process but screwing holds well. Pvc is not strong enough.
bikergja is offline
Old 10-25-2015 | 04:34 AM
try coosa board its a little pricy but it takes glass well, its rot resistant and will hold staples, very strong and light, use wood tools to work with it and they sell at TPI plastics right past the city line on rt 40...Im using a sheet for my engine hatch and I used a lot of it for my stringers and bulk heads
Bobbyyeah93 is offline
Old 10-25-2015 | 05:23 AM
rak rua's Avatar
Maybe someone can tell me if this is starboard?
Contractors are using this on the seat bases of my refit. They've already used it on the bow seats, now proceeding with rest of the seats. It's very strong, waterproof and seems easy to work with. The contractors I'm using are a professional boat building company, pretty big here in Thailand.
At the risk of sounding a little ignorant, I highly recommend it!
RR
Attached Thumbnails Rebuilding bolsters with something other then wood-image.jpg
rak rua is offline
Old 10-25-2015 | 07:02 AM
Thanks for posting this up. I too am looking to rebuild my front bolsters. The upholstrey is in good shape but sadly, the wood is starting to crumble so I'm going to try to see if I can remove the material and just replace the wood and then reuse the material. I really don't want to use wood again and this gives me some great ideas. Thanks again
JohnRork is offline
Old 10-25-2015 | 07:19 PM
masi242's Avatar
When I redid my bolsters some of the wood was bad I just used pressure treated, remember it lasted the first 25 years so you should be ok. The seat part of the old mc cloud bolsters used some mat fiberglass to stiffen it up an add some protection. I don't know how bad yours are, good luck
masi242 is offline
