Cooling system >
Cooling system
Cooling system
Old 10-21-2015 | 06:39 AM
Default Cooling system
i only have the bravo one stock water pickup, can i add another pick up ? what do you do ?
Bulitz is offline
Old 10-21-2015 | 06:58 AM
I would assume you need it for an innercooler?
JRider is offline
Old 10-21-2015 | 07:16 AM
why ?
ezstriper is offline
Old 10-21-2015 | 01:56 PM
No just to get more water in the motor
Bulitz is offline
Old 10-21-2015 | 03:17 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Do you have the low water pickup only, or high water pickup?
You can chamfer the holes a bit to pick up water pressure. What kind of water pressure are you running right now?
Sydwayz is offline
Old 10-21-2015 | 08:28 PM
You need to explain you situation more. If you are having cooling issues with your setup it may be something else. if you just want a offshore style pickup thats different.
Bawana is offline
