Go Back  Offshoreonly.com > Owners Forum > Powerplay
Question on new Imco steering installed on my 25 Sportdeck.. >
Old 10-26-2015 | 06:06 PM
NWfreerider's Avatar
Default Question on new Imco steering installed on my 25 Sportdeck..
Finally got everything hooked up on my 25 Sportdeck. I think I have all the air purged out of the system after filling and connecting the lines to the rams but can't be certain as I have never done this before[ATTACH=CONFIG]547007[/ATTACH]. I went lock to lock countless times on the steering wheel to get any air out. It doesn't seem to have any more air that wants to come out but if I grab each side of the wing plates and pull hard in each direction, there is a slight amount of movement. I really have to use a lot of muscle to make it move, so much that I'm making the trailer sway back and forth on its tires. The engines might have a total of 1/4" to 3/8" of movement. Should they be rock solid or is this normal?
Attached Thumbnails Question on new Imco steering installed on my 25 Sportdeck..-img_2529.jpg
NWfreerider is offline
Old 10-26-2015 | 07:01 PM
northernoffshore's Avatar
no rock solid..... keep bleeding
northernoffshore is offline
Old 10-26-2015 | 07:58 PM
Mine are stable with no movement at all. To bleed the final air out of the system this is what I did. I tried all of the other ways and none of them worked except this one. DaveM posted this a while back.
Marine machine told me to ....
open the fitting furthest from the transom first.
turn wheel 3/4 way to right.
close fitting after no bubbles.
open fitting closest to transom.
turn wheel 3/4 way to left.
Only thing I added was to make sure the cylinder that I was bleeding was not extended.
turbo rr is offline
Old 10-26-2015 | 11:03 PM
Turbo rr, when you say open the fitting do you mean open it all the way or just enough for fluid/air to come out?
Old 10-26-2015 | 11:11 PM
Let me ad that Ron at Imco suggested connecting the rear fittings to each other. The front fittings connect to the helm. With the lines like this, I cannot bleed the rears. Ron thought that since I was using my Hynautic/Seastar helm that came with the boat, my steering would have a better ratio since it isn't adjustable like the Capilano helm which would not fit under the dash.
Old 10-27-2015 | 08:42 AM
CIG3's Avatar
Similar to Turbo's process. This is how I do every steering system and have no issues.
http://www.everettperformance.com/PD...ING_SYSTEM.pdf
CIG3 is offline
Old 10-27-2015 | 09:39 AM
if your helm is a square model .. you have to use a fluid/air can also
Old 10-27-2015 | 12:19 PM
It is a round unit.
Old 10-27-2015 | 12:57 PM
It is a round unit.
got pics of it.... 2.0 volume like a seastar pro unit???
Old 10-27-2015 | 05:27 PM
I think I finally got mine correctly bled. New 2.4 helm and sea star tournament rams. Not quite as cool as your set up.....
But same principle.
I bled mine 4 or 5 times. Let it sit and bled it again the next day. I had a lot of micro bubbles. I'd get it tight one night and the next day it would feel sloppy again.
You can hose the ram bleeders together or run 2 lines into a clear bucket to recycle it back into the helm to keep bleeding.
Not sure what Imco recommends for fluid but I googled that for seastar you can use Napa hydraulic jack fluid or AW32 instead of blowing $20 qt on seastar ****
Go on YouTube. Some pretty good how to vids
scarab63 is offline
