Harmonic balancer ok to powder coat? >
Old 10-26-2015 | 06:16 PM
Default Harmonic balancer ok to powder coat?
Like the title says, Is it OK to powder coat the Harmonic Balancer? I am asking because of the rubber.
Thank you.
GLENAMY 242SS is offline
Old 10-26-2015 | 06:22 PM
no. powder coat oven temps are too hot
kvogt is offline
Old 10-26-2015 | 06:24 PM
Thank you.
I wouldn't used to design dampers for Schwitzer would compromise the rubber
turbo2256b is offline
Old 10-26-2015 | 07:48 PM
That is what I was afraid of.
Now I'm questioning the idea of powder coating the flywheel cover as it has rubber bushings also.
Old 10-26-2015 | 08:18 PM
BUP
No either but it can be a good thing for your pulley's if they get rusted up. The rust in the pulley grooves can wear belts in no time. Some Volvo Penta's have this problem badly and snap V belts - not good when it takes out the v belt for the impeller housing. just throwing it out there.
BUP is offline
Old 10-27-2015 | 12:47 PM
I would use some good epoxy paint such as KBS-Coatings.com
Old 10-27-2015 | 10:22 PM
1 MAIDEN AMERICA's Avatar
They use plastic and rubber plugs to plug threads, etc. when they powder coat and they live.
Smoke comes off my rear tires on occasion and the tires aren't compromised.
In theory you could probably do it.
But I wouldn't. lol
1 MAIDEN AMERICA is offline
