Spark plug gap with MSD >
Old 10-28-2015 | 04:50 PM
Tinkerer's Avatar
Default Spark plug gap with MSD
598 cubes, 8.6 to 1, What plug gap should I run with MSD ignition ( 6M )
Tinkerer is offline
Old 10-28-2015 | 05:24 PM
.035 would be fine.
horsepower1 is offline
Old 10-28-2015 | 06:09 PM
F-2 Speedy's Avatar
The same as a any Cheby back in the day, funny how things stay the same as things change........035 is a universal gap, Chevy, Brigs&Straton lol
F-2 Speedy is offline
Old 10-28-2015 | 06:25 PM
14 apache's Avatar
I like .035.
More gap will be harder on everything.
14 apache is offline
Old 10-28-2015 | 06:28 PM
I like .040 with msd
MDGperformance is offline
Old 10-28-2015 | 06:32 PM
SB
Everyone is correct (IMHO and experience) above.
Save bigger gaps for the beach. Hah !
SB is online now
Old 10-28-2015 | 06:37 PM
Gap depends on what heat range plug you are using.
Black Baja is offline
Old 10-28-2015 | 07:31 PM
Back in the day, if you had the "High energy ignition", you gapped the plugs at .060. If you didn't have the HEI, with a conventional ignition, you gapped them at .035 on most GM V8's.
I had several pontiacs, with factory HEI's. .060 was the recommended gap, never had an issue.
.035-.045 imo, is just fine for what you're doing. I've ran my plugs at both of those gaps, never seen an issue, or a difference either way, in my boat engines.
MILD THUNDER is offline
Old 10-28-2015 | 08:27 PM
14 apache's Avatar
I agree if you have a large distributor cap you can go big gap but most guys here only run a 3" distributor cap no good for big gaps.
Old 10-28-2015 | 09:43 PM
msd recomends 55 -60 for up to 10.5 c/r.35 to 40 will work every time up to 15 lbs boost.really no reason to widen the gap imo.
mike tkach is offline
