What's in your boating tool kit?
Just interested to know how much you guys carry onboard in terms of tools and equipment?
All our boats are different , I've got outboards so there's not as much I can do mechanically compared to the majority with inboards. Some of you guys do all the maintenance and work on your boat and know it all backwards so you might carry gear for every possible scenario. Some of us are not so knowledgeable so there's no point having a huge tool kit.
Im not an idiot and I know my way around boats but when it comes to electrical or in depth mechanical knowledge, I proceed cautiously. All I carry is a few screwdrivers, two different size shifters, pliers, pointy nose pliers, sharp knife, electrical tape, and a small container of spares (switches, bulbs, screws, nuts, bolts and fittings, specific to my boat which I have somehow collected. Full socket sets and a comprehensive array of wrenches would be a waste for me.
I'm not talking about when you're dialing in, tuning and setting up but more generally, a typical Sunday out with a few friends. What's in your toolbox and do you carry more offshore vs. inland use?
RR
RR
I carry a full socket set, set of end wrenches, screwdriver with changeable bits, pliers, spare hose clamps, electrical connectors, spare solenoid for trim pumps and starter, zip ties, fuel filter, filter wrench, 12v test light, misc. spare wire. Some will say that its excessive but I've never been stranded.
Ah yeah,carry one fuel filter,oil filter,all electronic parts plus cap and rotor for hei distributor,shaft packing hose clamps ,full set screwdriver,combination wrenches ,socket set ,strap wrench,adjustable wrenches 8,10,12. Pipe wrenches.machine screws and nuts zip ties mechanics wire,shaft packing 8 sparkplug,water pump impellar,snap rings and orings. Paint scrapers ,varnish paint(woodencruiser) cotter pins pry bar various serrated knives.um a mechanic totally self reliant.help others out all the time forgot about all the different sets of pliers and vice grips gallon of oil trans fluid funnel and more...toolbox weighs 70 pounds.......
tools
3/8 ratchet, 1 3 6 8" extentions, 5/16-3/4 socket set + 1 for alt pully, drive lock key, 1/4-3/4 end wrench set, 15mm end wrench, allen socket set, 1/4 drive torx socket set, 1/4 drive 3/8 12pt wobble, 1/4 drive 1/4 12 pt socket and 3" extention, 3/8-1/4 adapter, pick w/straight and 90*, wire crimper/stripper, wire cutter, razor blades, driver handle and bit set w/common and phillips 1 and 2, and sockets, test light, crecent wrench, telescoping magnet for bilge and 10# magnet for overboard, scanner, book, flashlight, super soaker, flush hose adapter, funnel, nitril gloves, paper and cloth towels
parts
impeller and housing, wire, string, duct and electrical tape, zip ties, couple wire ends, fuses, A/N caps and hose clamps, header drain plugs, shim stock, belts, lt bulbs, silicone, 1 qt engine, P/S, drive, blower, trim oils, astrolube, keys
1st aid kit with a bunch of stuff
trailer
jack, ramp, lug wrench, tire, hose, cleaner
home
engine and drive stands, gantry, drive alignment tool, shift cable adjustment tools, prop socket, transom assy hose socket, shift bellows clamper, swivel pin wrench, prop file and hammer, oil filter wrench and center punch, miti vac, syringe, drive oil pump, grease gun, lubes, sealers and glues, safety wire and pliers, 1/2' ratchet, sockets, extentions and torque wrench
I think you could do everything except rebuild a drive with this list.
parts
trailer
home
