merc. 500 efi vapor lock.
Old 11-01-2015 | 09:24 AM
Default merc. 500 efi vapor lock.
Anyone have the pn. For the merc auxiliary electric fuel pump kit..For early efi,s without the mechanical fuel pump on the raw water pump.
Velocity Tom is offline
Old 11-01-2015 | 10:43 AM
BUP
The latest part number is 862264A7
if you need one I can get you a current brand brand new kit. With warranty from the day you buy it.
BUP is offline
Old 11-01-2015 | 04:52 PM
Thank you for the no. I have a hook up. I just wanted to compare no.there are a few.
Old 11-02-2015 | 09:51 PM
Just return the fuel to the tank and be done with it. If you can do the work yourself, you can do it for about $50 worth of hose and fittings. I have done numerous posts in the past about how to get the return to the tank. It's really pretty easy and you don't need another pump that can fail. On top of that, the add on pump is nothing more than a bandaid.
Eddie
Young Performance is offline
Old 11-03-2015 | 03:34 PM
You dont think it will run out of fuel? The cool fuel pump pushes better than it pulls. I have thought about it.
Old 11-03-2015 | 03:43 PM
offshoredrillin's Avatar
You're miles ahead by getting rid of the factory pumps and replacing with an aeromotive A1000, also if you are doing any power adders or upping the hp at all the factory cool fuel is very restrictive for anything other than stock. depends on where you want to go with it. you can even rig the pump down by the cool fuel and have it as a bolt on unit.
offshoredrillin is offline
Old 11-03-2015 | 04:08 PM
Nope boats worth more stock.
