Looking for a pair of #5 speedmaster drives in ontario canada >
Old 11-06-2015 | 08:20 PM
crazy canuck's Avatar
Default Looking for a pair of #5 speedmaster drives in ontario canada
Looking for a pair of speedy #5's drives 1.48 ratio in ontario , canada
crazy canuck is offline
Old 11-06-2015 | 08:29 PM
northernoffshore's Avatar
http://www.offshoreonly.com/forums/s...ine-drive.html have this if you run staggered
northernoffshore is offline
Old 11-06-2015 | 08:37 PM
Looking for drives northern offshore
Old 11-06-2015 | 09:22 PM
RMPRam's Avatar
I have a perfect pair of #5 drives. They are under 10 hours, fresh water use and 1.48:1 ratio with 2nd design upper cases and fully polished lowers. You can find cheaper sets of #5's but you won't find a newer, never been in salt water, that don't need to be completely gone thru, than the ones I have. The cases have not been rebuilt and have absolutely no salt damage. They still have the original Mercury part # tags on them. And as an additional bonus they have 1" spacers installed and if you choose not to need or use the spacers, I will supply a set of studs to remove them and you can return them to their original configuration. Give me a call and lets talk. Check out my ad in the classifieds.
Gary Kollofski
612-247-7081
Attached Thumbnails Looking for a pair of #5 speedmaster drives in ontario canada-57-chev-10-3-2015-008.jpg   Looking for a pair of #5 speedmaster drives in ontario canada-5s-gimbals-boxs-etc-030.jpg
RMPRam is offline
Old 11-07-2015 | 07:51 AM
Sick Stinger's Avatar
Brotherhood #1
If your intersetd in either of the 2 sets I emailed you let me know.
Sick Stinger is offline
Old 12-07-2015 | 11:04 PM
ttt
Old 12-08-2015 | 07:03 AM
Brotherhood #1
So a few sets out there to buy listed here but your still looking? There is only some many SSM 5 boats that get parted out
Old 12-08-2015 | 09:22 AM
Mike did you get the fountain with the 5's ?
Old 12-08-2015 | 01:02 PM
What gear ratio Mike?
endeavor1 is offline
Old 12-08-2015 | 01:05 PM
Veteran: Army
Default #5
i have a pair 150 ratio will take $14000.00 plus ride i am in il. ph 309-925-4620
kgz3 is offline
