Recomendations to Remove Bottom Paint >
Old 09-18-2002 | 07:22 PM
Da Patriot's Avatar
Angry Recomendations to Remove Bottom Paint
I am newer to the board. I need some advise on how to remove bottom paint. I want it all off with having to do as little work as possible and not ruining the bottom. I have been told that I may gain up to 5mph by removing this. I'm not exactly sure what kind of paint is on it but I don't think that it is teflon or micron. Any help will be appreiciated.
Thank You
Da Patriot is offline
Old 09-18-2002 | 07:43 PM
Audiofn's Avatar
Charter Member #232
Do a search on the subject and you will find a couple posts I think in the Technical Q+A area. There have been suggestions from sand blasting to high preasure water, to oven cleaner.
Jon
Put your best foot forward!
Audiofn is offline
Old 09-18-2002 | 07:55 PM
puder's Avatar
speel chekk this fokker!
oven cleaner works o take normal paint off i don;t know if it works with bottome paint. Sandblasting with walnut husks or corn meal i hear works. Take it to somebody that is a professional sandblaster who FREQUENTLY removes bottom paint. If they screw it up it could cost you more speed than you're already loosing.
Pardon me, while I whip this out!
puder is offline
Old 09-18-2002 | 07:58 PM
HyperBaja's Avatar
5 mph? no. MAYBE 1. not 5 though.
HyperBaja is offline
Old 09-18-2002 | 08:08 PM
Madcow's Avatar
I agree only 1 mph. Good paint striper and a pressure washer will take 95% of it off Finish with striper and a scraper. Anything left sand with fine paper. Good luck.
Madcow is offline
Old 09-18-2002 | 08:22 PM
mfb357's Avatar
have it done using corn husk material, it wont hurt gel coat
mfb357 is offline
Old 09-20-2002 | 07:22 AM
Da Patriot's Avatar
I work for a construction company with many water blasters. What kind of PSI could I use. Keep in mind that i don't want to damage the fiberglass but I want to get as much paint off as possible.
Old 09-20-2002 | 07:35 AM
NASTY HABIT's Avatar
I recently stripped bottom paint using West Marines stripper bottom paint remover....it was a task 21 ' V hull took a freind and i a long day to complete . It actually did a good job ..i was suprised at the results...but this was blue gel and when finished stripping we started prep for a restoration and complete paint job so the results didn't have to be perfect ......not sure how it would be on a white hull that would be left alone after the paint was removed
good luck ....
NASTY HABIT is offline
Old 09-20-2002 | 10:09 AM
Offshore Addiction
hey guys,oven cleaner does work very well and will not disturb the gel coat at all......oven cleaner,then let soften paint,then pressure wash.....try it,an old salt showed me this
Old 09-20-2002 | 03:48 PM
Originally posted by Too Old
It was a big job and I learned my lesson about boats with bottom paint.
Yeah, Now he just gets boats and repaints everything but the bottom.
Griff is offline
