Milling heads for compression >
Old 11-25-2015 | 06:24 PM
Default Milling heads for compression
How much will have to be milled off a dart 308 head to reduce the volume by 5 or 6cc's? Is there a chart?
Unshrouding the valves and clean up will add a couple cc's to so may be up to 8 or so.
Thanks.
Mr Maine is offline
Old 11-25-2015 | 06:36 PM
I would cc them then refill with the volume I was looking for and measure the gap between the water and the head surface. Not exact but will get you a good idea. Just a thought.
GLENAMY 242SS is offline
Old 11-25-2015 | 06:43 PM
that will work just need a depth mic and level the head and check the depth in a couple of spots
MDGperformance is offline
Old 11-25-2015 | 06:49 PM
Ok, liquid tends to "grab" at the edge and anything you stick near it, but that will work for an initial stab at it. Will make a final cut when it's close.
Mr Maine is offline
Old 11-25-2015 | 06:57 PM
creating the meniscus
always measure from the bottom, low spot
Old 11-25-2015 | 07:47 PM
.006 per cc for flat mill
billy boats is offline
Old 11-25-2015 | 08:02 PM
So .035ish then? Good ballpark.
Mr Maine is offline
Old 11-25-2015 | 10:58 PM
Use a surfactant, soap?
Cole2534 is offline
Old 11-26-2015 | 02:01 AM
If you take off more than .030, you will most likely need to have the intake milled to fit also.
Griff is offline
Old 11-26-2015 | 07:48 AM
^^And might need thicker intake gaskets^^
Jonesyfxr is offline
