mwc ballstic prop 23 pitch
They are thin blade prop with the cut / semi straight cut across the tip of the prop blades. They were one of the fastest 3 blade props for alpha one and GEN II outdrives back in the day. Worked well for smaller light weight apps - 16 thru 23 ft hull - Glastron / VIP and so on apps. Like I said lite weight apps.
IMO probably not the best at all ( average to below ) for a bravo app plus being very thin blade alot prop blade flexing could take place. At one time Attwood owned these props and MW has taken over for X amount years. MW quality is not that good and I think most everything made for them is Mexico or Asian built with the lowest cost as possible.
Besides the poor quality control, the blade area and diameter are not large enough to support the performance of your hull.
Brett
[email protected]
[email protected]
