HP525 ECM Question >
HP525 ECM Question
HP525 ECM Question
Old 12-20-2015 | 10:27 AM
Default HP525 ECM Question
Does the stock ECM on an HP525 need to be re-calibrated after the engine is punched out to 540cid? Thanks!
Mike A. is offline
Old 12-20-2015 | 10:42 AM
F-2 Speedy's Avatar
If your referring to the 525 EFI, I would, you should increase the injector size for the larger displacement also, what else did you do besides bore it ? I think a remap is in order
F-2 Speedy is online now
Old 12-20-2015 | 12:10 PM
Yes
Griff is offline
Old 12-20-2015 | 12:11 PM
BUP
Yes as well
BUP is offline
Old 12-20-2015 | 01:17 PM
We changed rockers to 1.8. Everything else stayed same. I pulled motor to fix issues from blown head gasket. Damage not catastrophic.
HP at 5300 was 620 on dyno with stock ECM cal. That said, what are potential issues if we leave ECM as is? Thanks?
Mike A. is offline
Old 12-20-2015 | 01:31 PM
What were the afr ratios on the dyno if you make the engine bigger you will need more fuel to keep it in the same safety zone as the stock engine,lean is mean but you up your risks of a meltdown
MDGperformance is offline
Old 12-20-2015 | 01:37 PM
F-2 Speedy's Avatar
If you lean out a hole, your not gonna be a happy camper, thats a good number for those heads, a little fatter as far as fuel goes would be piece of mind, do you have the arf #'s........
Old 12-20-2015 | 07:43 PM
lean means boom
jdf4068 is offline
Old 12-21-2015 | 07:56 AM
Call Eddie at Young Performance. He has two of my 525's, he can tell you exactly what you need to do.
twinscrews is offline
Old 12-21-2015 | 10:07 AM
The PCM 555 has a cubic inch "compensator". It's basically a matter of telling it that the engine is a 540 instead of a 502. There are other gains to be had with timing, etc. What type of AFR's did it have on the dyno? If you don't know, you would be wise to find out.
Eddie
Young Performance is offline
