Best 33c cable?
I am a big fan of the uflex Mach zero cables. Alittle pricey but seem to really hold up nice and seem to be slightly more flexible then the teleflex extemes, where my indicator panel is mounted it is an absolute b**** to get the cables bent properly and aligned and when I switched to the Mach zero they definitely flexed easier. If I only had 10 hands and 50 fingers to hold all of the pieces it would be cake lol.
I agree on the Uflex (Ultraflex). They are the best cables that I have ever used. They are more expensive but there is a reason. They have a SS jacket on them so it the outer covering gets cut, it won't rust like the Morse cables do. It also has a teflon liner inside for the core to ride in. THey will make incredibly tight bends and still be smooth as can be. I haven't found another cable that will do that. You can get that cable to make a 6" or less diameter circle and still work.
Eddie
Eddie
Morse is Teleflex inwhich is Sea Star solutions. The Extreme cables are good cables as well.
Contact Bill at Uflex as he can provide all the info you will ever need about their products. I do know him personally and talked to him about alot of their products over the years. On a side note he use to work for Wellcraft who knows alot about the marine industry overall.
Eddie
Eddie
