Mercruiser 370 trs rebuild/power upgrade info/help >
Old 01-05-2016 | 09:03 PM
Default Mercruiser 370 trs rebuild/power upgrade info/help
Hey all new to the site looking for some insite.. Have a 87 fountain with 370hp 454s. Looking to rebuild and make a little more power. That being said seem to be stock other than the flow through water circulator housing.. And also noticed it has roller rockers. Wasn't the roller rocker arms the 420hp package..? Any info on rebuilding upgrades and hp range I should be safe with the 454 blocks internals etc.. Thanks in advance Jacob ..
jpilkinton is offline
Old 01-06-2016 | 08:28 PM
Rookie's Avatar
The 370 from what I have read it has forged crank, pistons and rods. Rectangular port heads with an aluminum high rise intake and roller rockers. 8.8:1 compression. Great base engine.
Rookie is offline
Old 01-12-2016 | 07:38 AM
CIG3's Avatar
A little head work a larger carb and cam change should get you in the 420 range. I'm sure there are a few guys who will chime in with some good combinations.
CIG3 is offline
Old 01-12-2016 | 11:38 AM
how fast does the boat go now?have you checked top speed with a RADARR gun.
mike tkach is offline
