Outdrive repaint what putty can be used ? >
Old 01-06-2016 | 07:29 PM
Default Outdrive repaint what putty can be used ?
I am looking to repaint my bravo drive and entire gimbal / transom assembly ... Most of it is pitting free but the drive does show minor corrosion here and there.
I am going to be sandlblasting every part including the drive but would rather not take the drive appart , I know I should use the Zinc Chromate primers but what can I use to fill in minor imperfection ? I am thinking of some jb weld ?
Also I am decent at spraying with a rattle can but is there a non aerosol primer and paint available by Merc ?
Ram750 is offline
Old 01-06-2016 | 07:54 PM
jeff32's Avatar
i used liquid metal, worked fine!
jeff32 is offline
Old 01-06-2016 | 07:57 PM
jeff32's Avatar
similar to this
http://www.amazon.ca/Permatex-25909-...s=liquid+metal
jeff32 is offline
Old 01-06-2016 | 08:04 PM
Rookie's Avatar
If I had to do it again I would not remove the original paint. I would scuff it up and use it as a good base adhesion to the aluminum. I tried a few different fillers. Lab metal and few others. I ended up using Dynatron Dyna-deLITE to fill my pits. I put some on a piece of aluminum and let it sit in a 5 gallon bucket for a few months. It is water resistant. It's held up great for the last 5 seasons. There are a few threads in the drive section on this subject and a few more alternatives.
Refer to post #10.
http://www.offshoreonly.com/forums/r...-progress.html
Rookie is offline
Old 01-06-2016 | 10:46 PM
I used this stuff to fill in some pitting on my drives. Worked good, and sanded nicely.
http://www.amazon.com/gp/product/B00...ilpage_o03_s01
MILD THUNDER is offline
Old 01-07-2016 | 12:22 AM
BUP
Marine Tex been using it for over 20 years now. They have a white color inwhich is great for fiberglass hulls minor to medium stuff for filling and sanding. They also have a grey color to use. You can use either color for whatever.
Years ago a boat owner had a OMC cobra outdrive that froze broke a long crack across the bullet - he wanted a cheap band aide fix for filling and fixing the long crack all the way across the bullet. We used Marine Tex - kept building it up and then sanded & painted it to match. We pressure tested the crack repaired outdrive - filled it with gear oil - then sent him on his way with the cheap band aide repair. This was in 1994 and I knew it lasted for 5 years min. - but after that we never seen him again. I was sold on Marine Tex since then. Just saying.
BUP is offline
Old 01-07-2016 | 01:29 AM
I would not blast all the original paint off. The Merc factory black paint sticks like no other. I would just scuff, fill pits and feather.
Griff is offline
Old 01-07-2016 | 07:55 AM
Merc has spent millions getting the correct combination of primer and paint for protection and adheision....nearly every repaint where the owner stripped the cases to raw were unhappy with the quality and adheision they were left with in a short time
speicher lane is offline
Old 01-07-2016 | 09:10 AM
I agree. Nothing will hold up better. This includes a drive sprayed with DuPont Imron. I've always used a product called Allmetal. Works great and holds up to abuse. Sands very easily.
Ryan00TJ is offline
Old 01-08-2016 | 09:51 AM
Thanks for all the answers , the problem with keeping the factory paint is that some garbage hardware store crapped as been brushed on ... several coats of it .... Specially on the transom assembly ...
A body shop owner and good friend of mine is suggestion an Epoxy primer with a single process Urethane paint. What do you guys think ? He also said that bringing it down to metal is not necessary.
Ram750 is offline
