#3 drives on TRS BOAT IS IT WORTH IT???????????????
Registered User
I have nothing but good luck here, with questions. I have a 86 scarab 400 basically a 38 scarab with bbc 597 hp each. It currently has trs drives which i just got and are really clean.
My buddy has a set of super duper clean ssm #3s gimbles and drives. I can gett for under 5k for both.
1st- is it worth it speed wise even a little is good. Hahahahaaa
2nd- what is entailed in the change out, cutting bigger hole easy, refiberglassing to make new hole not so easy
3rd- props has anybody ran these #3s on a scarab trs boat, boat and what are my prop options?
4th- how much different is the x from a trs drive?
Any and all information would be greatly appreacted.
Steve vasquez 916 247 0623
how complete of parts? tailstock of trans is different, I think you have to re-set engines, some glasswork in transom, props, trim rams, inner and outer transom assemblies.
if you can get the parts cheap and they are good it will live MUCH longer the TRS will, speed you probably wont see much if any takes more power to spin a 3 but will not blow gearsets all the time...
are they 3's or 3A's. parts for the 3 are harder to find and are small prop shaft and there are limitations on finding props. 3A's are easier to find parts for and use the bigger prop shafts.
I think someone on here did the same thing (Mild Thunder?) they said that the cut out for the SSM III is bigger than the TRS, so that should not be a problem. As long as you get everything from the tailstock back you should be good (I think) I think you will have to remount the front engine mounts. I think X dim is the same.
