WTB MSD Dist 85551 >
WTB MSD Dist 85551
WTB MSD Dist 85551
Old 01-22-2016 | 12:36 PM
Mr Gadgets's Avatar
Charter Member #601
Default WTB MSD Dist 85551
Looking for a used MSD either 85551 or 85561 distributor. I only need the housing and shaft. If you have one with bad pickup that would be perfect. I don't need a cap or rotor either. Let me know what you have and are willing to give up in the Inexpensive range.
Thanks!
Dick
Mr Gadgets is offline
Old 01-22-2016 | 02:55 PM
phughes69's Avatar
Dick are you looking for one to turn into a cam sensor for the megasquirt?
phughes69 is offline
Old 01-22-2016 | 04:17 PM
Mr Gadgets's Avatar
Charter Member #601
Yes I am.. Have anything for me???
Old 01-23-2016 | 09:32 AM
TomFTM's Avatar
I think I have one. I will take a look sometime this weekend . Dealing with blizzard now.
TomFTM is offline
Old 01-23-2016 | 10:27 AM
phughes69's Avatar
Dick, this is what I am going to use on my Megasquirt build. Its a camshaft pickup that was used on 1999-2000 chevy P30 trucks. The part numbers are PC277 or 1104068 or 213-350 I am using this because it is low profile and i dont have to mess with altering a distributor cap to cover it.
http://www.ebay.com/itm/171386981989...84.m1436.l2648
For the crank pickup I am using a Holley 556-103 Universal BB Chevy crank sensor mounting kit It uses OEM sensors and seems pretty simple.
http://www.ebay.com/itm/381430024711...84.m1436.l2649
Unfortunately EFI Connection does not make a crank pickup similar to the OEM that would fit a Mark IV block with out major work to the front timing cover.
https://www.eficonnection.com/eficonnection/24xBBC.aspx
Attached Thumbnails WTB MSD Dist 85551-31tfs0hohel._sy355_.jpg   WTB MSD Dist 85551-556-103.jpg
Old 01-23-2016 | 10:28 AM
phughes69's Avatar
If neither of these work, I have a GM branded MSD distributor lying around for you.
Old 01-23-2016 | 06:46 PM
Mr Gadgets's Avatar
Charter Member #601
phughes
Any Idea what gear is on that unit? I need a cast iron gear to be compatible with my cam gear. I like that unit, was hoping to find an MSD so I can mod it for my use, knowing the 8531 gear is cast iron. Just found my cam gear toasted..
On the Crank Sensor I was thinking of the DIY unit with their toothed wheel and sensor.. Just have to make a bracket for it. Let me know what dist you have If you would please!
Tom, after the snow clears let me know what you have.. Thanks!
Old 01-25-2016 | 09:22 AM
TomFTM's Avatar
Tom, after the snow clears let me know what you have.. Thanks![/QUOTE]
Here is what i have , it needs a cleaning and a new bearing . $40 including shipping to u. [ATTACH=CONFIG]550088[/ATTACH]Tom
TomFTM is offline
Old 01-25-2016 | 09:35 AM
Mr Gadgets's Avatar
Charter Member #601
Tom,
Do you know what model that is??
Thanks.
Dick
Old 01-25-2016 | 10:04 AM
TomFTM's Avatar
Originally Posted by Mr Gadgets
Tom,
Thanks.
Dick
yes, it is the 8560 with the collar machined off. I had it machined off then used a slip collar. dont have the slip collar . Tom
TomFTM is offline
