Trim Tab re-install >
Trim Tab re-install
Trim Tab re-install
Old 01-26-2016 | 08:20 AM
Default Trim Tab re-install
I am going to reinstall my tabs and just wanted to know what you guys are using 5200 or marine silicone
class6 is offline
Old 01-26-2016 | 11:00 AM
i use 4200.it seals good and won,t peel the gel coat off if you need to remove them in the future.
mike tkach is offline
Old 01-27-2016 | 07:51 PM
I used 4200 on my tabs,
MRALLEN is offline
Old 01-27-2016 | 08:36 PM
Yep. 4200
thirdchildhood is offline
Old 01-28-2016 | 07:43 AM
Boatlife caulk
FBRONCO is offline
Old 01-28-2016 | 06:41 PM
I would use 4200. It has the same sealing as 5200 but with 1/2 of the adhesive strength.
Griff is offline
Old 01-28-2016 | 07:27 PM
They are going on tomorrow.
class6 is offline
