Manifolds hit headbolts. >
Old 01-30-2016 | 07:39 PM
Default Manifolds hit headbolts.
I have completely assembled my longblock. I have 088 heads. I used ARP bolts with the washers. I am mocking everything up. I changed alot so I have many details to finalize with bolts, brackets, hoses, etc. Anyways, I bolted my EMI Thunder exhausts up. They went on but were super hard to get on. The bottom of the manifold hits the head bolts. I would like to let the manifold come down to give me better port alignment and also make the install easier.
I think my options are:
1: Grind head bolts 1/16 of an inch.
2: Remove the little washer under the ARP bolt.
3: Take a flapper wheel and sand the underside of the manifold to give me the 1/16" clearance.
4: Run it as is with everything touching and jammed on.
I don't want to compromise the headbolts in any way. I am leaning toward clearancing the manifold. Any reason not to?
79formula is offline
Old 01-30-2016 | 09:09 PM
what exhaust manifold gaskets were you using? Remflex makes a super thick gasket that we have used with good success on headers/manifolds that the flange surface has been warped alittle. They might give you that extra smidge you're looking for. They are twice the cost unfortunately.
mickeymcclgn is offline
Old 01-30-2016 | 09:15 PM
With iron heads why do you need the washers?
Mr Maine is offline
Old 01-30-2016 | 09:22 PM
i would remove the washers on the bolts that hit and apply extreme pressure lube on the underside of those bolts heads.
mike tkach is offline
Old 01-30-2016 | 09:33 PM
Originally Posted by mike tkach
i would remove the washers on the bolts that hit and apply extreme pressure lube on the underside of those bolts.
Can I remove the washers one at a time and not have to get new gaskets and do the bolts in sequence again?
Old 01-30-2016 | 09:35 PM
washers
f_inscreenname is offline
Old 01-30-2016 | 09:52 PM
yes
Old 01-31-2016 | 03:41 PM
I removed the washers. It worked perfectly.
Old 01-31-2016 | 08:48 PM
Just be sure that the bolt holes are tapped deep enough and the bolt doesn't start to bottom out before it tightens down to the proper torque. You would lose some clamping load on the head gasket if that happens.
Eddie
Young Performance is offline
Old 01-31-2016 | 09:07 PM
Eddie
from his other threads,he has 454's so the holes are open to the water ports,,no need to worry about depth,now if they were gen5/6 502's,then he'd definetely have to check.
sutphen 30 is offline
