Trailer tires
Old 01-31-2016 | 01:24 PM
Default Trailer tires
Does anybody recommend a good trailer tire. Besides Carlisle,size 225/75/15
598 is offline
Old 01-31-2016 | 01:30 PM
F-2 Speedy's Avatar
MAXXIS ...................don't buy carlisle
F-2 Speedy is offline
Old 01-31-2016 | 06:19 PM
Anything but car$hitlise...
PARADOX is offline
Old 01-31-2016 | 06:32 PM
Step up in load range.
mine require E and I run G instead
offshorexcursion is offline
Old 01-31-2016 | 06:33 PM
CNC's Avatar
CNC
For what it's worth, I bought these
(http://www.ebay.com/itm/2-X-Freestar...RWVhho&vxp=mtr)
I bought 2, then 2 more, finally 2 more (all six tires replaced) NO problems. Kept breaking belts before. (Goodyear etc) The shop that mounts my tires said most all trailer tires
are made in China.
Randy
CNC is offline
Old 01-31-2016 | 07:05 PM
Another input for NO Carlisle - they don't stand behind their warranties.
Buy the highest load tire you can find in the size you need.
32fever is offline
Old 01-31-2016 | 08:13 PM
Maxxis
underpsi68 is offline
Old 01-31-2016 | 08:25 PM
masi242's Avatar
Sydways please reply!
masi242 is offline
Old 01-31-2016 | 08:39 PM
E load light truck tires. No trailer tires.
ToMorrow44 is offline
Old 01-31-2016 | 08:44 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Same advice I always give:
1) Step up to 16" wheels if at all possible. Even if you have to raise your fenders a bit, it's worth it. Trailer wheels are cheap. More diameter means less heat.
2) Get LT E-rated truck tires, like discussed on several other threads; on the 16" wheels aforementioned.
3) If you have to stay with 15" trailer tires, go with the biggest size you can fit. Again, more diameter means less heat.
4) I will only buy Maxxis brand trailer tires. They are the best thing on the market. A friend did have a blowout of a sidewall on a brand new Maxxis tire, but we feel like that was an isolated flaw. Maxxis makes the only E-rated 15" trailer tires that I have found:
http://www.maxxis.com/trailer/traile...nflation-chart
There are quite a few other threads on this topic.
Definitely do not buy Carlisle.
I can't recommend Goodyear Marathons.
I've bought all of my Maxxis tires on eBay.
Be sure to care for your tires properly; also many other posts on this topic.
Sydwayz is offline
