2005 Mercury 250EFI/300X Outboard >
Old 02-03-2016 | 03:29 PM
From: Central Square & Fishers Landing, 1000 Islands NY
Default 2005 Mercury 250EFI/300X Outboard
2005 250 EFI Merc with 300x heads, 300x intake, Simon Motorsports injection plate with his big bore throttle body, Boyesen reeds, poppet valve diverter, cut exhaust can, lightened flywheel, adjustable fuel pressure regulator, reflashed ecu, 300x oil injection pump and 1.62 ratio sport master. Motor only has about 100 hours on it. I bought it from a buddy that had it on his 22 Talon and it ran 99 hitting the limiter (7000 rpms) with a 28 Drag 4. I was going to put it on my 20' Seebold Eagle but way too many projects and not enough time. $8500 Motor is located in Syracuse, NY.
[ATTACH=CONFIG]550483[/ATTACH][ATTACH=CONFIG]550484[/ATTACH][ATTACH=CONFIG]550485[/ATTACH]
Attached Thumbnails 2005 Mercury 250EFI/300X Outboard-11902324_10207436390334659_1640698533763633972_n.jpg   2005 Mercury 250EFI/300X Outboard-photo-1.jpg   2005 Mercury 250EFI/300X Outboard-photo-2.jpg
1000 islander is offline
Old 02-07-2016 | 01:53 PM
Motor is currently in a crate and can be loaded into the back of your truck or loaded onto a trucking company's truck, you arrange the shipping.
Motor also comes with a bunch of white faced Gaffrig gauges including liquid filled speedo, tach, fuel pressure, water pressure, volts, trim, and fuel level.
