280 with 630hp speed >
Old 02-06-2016 | 09:05 PM
Default 280 with 630hp speed
Can anyone tell me how fast a 280 would be with 630hp?
Just doing some winter dreaming.
underpsi68 is offline
Old 02-07-2016 | 11:02 PM
I would estimate 82-84 GPS
Revd Up is offline
Old 02-07-2016 | 11:05 PM
I have a friend with a older 26, that he says is around 600-625 Hp. He says it runs 90. But I have never seen it
fatherb68 is offline
Old 02-07-2016 | 11:09 PM
I would agree more with Revd up
Old 02-08-2016 | 07:34 AM
I seen a video with Kenny that the 290 with a 525 should do 85. I thought/hoped it would be closer to 90 but I'm only in the dreaming stages now lol.
My concern is that damn bravo drive. Has any one got an arneson drive to work on a smaller Velocity?
Old 02-08-2016 | 08:08 AM
Put a imco on it. You will be much happier
Old 02-08-2016 | 10:14 AM
Revelocity's Avatar
Agree on the 82 - 84 MPH. The 290/VR-1 hull is faster no question. If you throttle it properly you should be just fine running a Bravo with 625 HP on a 280. My 280 has 615 HP and reliably ran a STANDARD Bravo X for many years. Bravo XR's are rated for 600 HP and the Velocities are more Bravo drive friendly then step hulls so I'd go that way first. If you're still concerned I'd look into the Bravo Drive Guardian system which Saris Racing has used very successfully for a couple of OPA racing seasons. There's no Velocity single arneson set-ups that I'm aware and probably for good reason. Besides being a very expensive proposition for likely a 10 year old plus 280, the performance outcome is uncertain and there are other practical drawbacks as well.
Revelocity is offline
Old 02-09-2016 | 08:44 PM
Thanks for the info everyone.
How is the 29 different than the 280? I'm talking about the weekender, not the vr. I always thought they were very close.
Old 02-10-2016 | 04:22 PM
I agree with Revd Up, I've got 798hp , has run honest 96 couple times on gps and gps speedo, but will run 93 anytime with bravo. Any faster would need imco lower or more power it would need imco upper.
r015 is offline
Old 02-10-2016 | 05:18 PM
It should run 90 to 95
letstalkboats is offline
