Cruising speed - too boring topic >
Old 09-21-2002 | 05:48 PM
Default Cruising speed - too boring topic
Hi!
All of us discuss top speed. However, most of the time we cruise along the river / lake / ocean. So, to bring a "boring" topic forward:
What is your crusing speed at 4.000 rpms and 4.500 rpms? 3.500 rpms and 4.000 rpms for inboards?
My ol' lady Phantom 25 w/Promax 300 runs 52,5 mph at 4.000 rpms and 59,5 mph at 4.500 rpms. Tempest 26 blueprinted - 1:1.75 gears. Not bad for a heavy offshore hull (2.500 pounds). Top speed in the spring 78 mph at 6.100 rpms. 76 mph at 6.000 rpms in the summer.
Look forward to hearing back from ya.
Cheers, Toffen - Norway
Toffen is offline
Old 09-21-2002 | 06:55 PM
KN
32' Sunsation twin 496 Mag HO's 6200 Lbs. dry 6800 +/- full of fuel. Regular Bravo One drives 1:1.5 with 28'' Bravo One props (stock)
3500 RPM 57.3 MPH on GPS
4000 RPM 65.1 MPH " "
4500 RPM 72.5 MPH " "
4900 PRM 77.6 MPH " " Top Speed at Max RPM
All speeds are an average of two runs in opposite directions.
Kirk
KN is offline
Old 09-21-2002 | 10:39 PM
Dave M's Avatar
Veteran: Navy
24 Superboat, 454 Mag, 26" Bravo1
3300 = 50 MPH
3700 = 55 MPH
Those are my numbers from today. 2 adults, 1 kid and full gas.
Dave M is offline
Old 09-22-2002 | 05:56 AM
71= 4000
audacity is offline
Old 09-22-2002 | 06:05 AM
Jassman's Avatar
76 @ 4000
Jassman is offline
Old 09-22-2002 | 07:17 AM
Funny, I tried to get this topic going on the Fountain forum and no one would post. You can't run WOT forever !
ed
Interceptor is offline
Old 09-22-2002 | 07:56 AM
BillR's Avatar
OSO Moderator
PowerQuest 340 w/twin 496 Mag HO's 7900 Lbs. dry 9320 with some fuel, gear & people. These results are with Bravo 1 28's labbed by York:
Spped vis Gaffrig GPS speedo
3500 RPM 49 MPH
4000 RPM 62 MPH
5170+/- RPM 79 MPH Top Speed / Max RPM
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 09-22-2002 | 09:19 AM
Shanghied Again's Avatar
Registered User
Default Donzi 26 ZX 502/415hp
3500 rpms 42mph
4000 rpms 55 mph
5200 rpms 68 mph
And thats respectiful for a heavy good rough water boat
Attached Thumbnails Cruising speed - too boring topic-sarasota-donzi-pic.jpg
Shanghied Again is offline
Old 09-22-2002 | 02:20 PM
Indy's Avatar
Member #154
Shanghai...what kind of prop are you turning to get 52 out of 3500 rpms With a single 502
Indy is offline
Old 09-22-2002 | 03:42 PM
Registered User
Indy That was a mis print 42, I hit a 5 instead of a 4 , The other speeds are correct. I run a shaved 26pitch to a 25 pitch 4 blade with a twin stepped hull. I will re edit, Thanks
