2 Mark IV 450 HP. 1, Gen 5 450 HP
I have in the shop
2 ~ Mark IV 454s Bored 60 over, Rectangular 088 Heads, Forged internals, 4" stroke Steel Cranks, Melling 77 Oil Pumps , Flat tappet Cam, Roller Rockers, etc. ZERO HOURS Air Gaps with Holley DP carbs. Everything rebuilt and refreshed. Paint color to suit $5750 each
! ~ Gen 5 ,Zero Hours,
GM Block Gen V 4.28" Bore
GM Heat Treated Forged Crank 4.0" STD
088 Ported Rectangular Heads, ...2.25, 1.88 Valves
Melling High Volume Oil Pump
Forged H Beam Rods
Forged Domed Pistons 4.28"
New Rings
HP Flat Tappet Cam
New Comp Valve Springs
Comp Retainers
Crane Rocker Studs
Felpro MLS Head Gaskets
Comp Cam Roller Rockers
New Main Bearings
New Rod Bearings
Forged Heat treated Crank,
Everything is rebuilt, Paint color to suit
$5750
1~ 454 Std Bore
Zero Hours,
GM Block MarkIV Four Bolt Mains
Forged H Beam Rods
Forged Domed Pistons 4.25"
New Rings
HP Flat Tappet Cam
Comp Retainers
Crane Rocker Studs
HP Flat Tappet Cam
New Main Bearings
New Rod Bearings
Paint color to suit
$5750
Can DYNO ALL motors, Shipping extra
Forged H Beam Rods
New Rings
HP Flat Tappet Cam
Comp Retainers
Crane Rocker Studs
New Main Bearings
New Rod Bearings
$5750
1~ 454 Std Bore
Zero Hours,
Forged H Beam Rods
New Rings
HP Flat Tappet Cam
Comp Retainers
Crane Rocker Studs
HP Flat Tappet Cam
New Main Bearings
New Rod Bearings
Paint color to suit
$5750
