Best anchor type for Lake Cumberland >
Old 02-22-2016 | 05:37 PM
Revspan's Avatar
Default Best anchor type for Lake Cumberland
Any advice for a 7k # 29' boat?
What is the bottom like? How deep should you plan for?
Thanks..
Revspan is offline
Old 02-22-2016 | 05:45 PM
Danforth with a lot of line.
TBAG is offline
Old 02-22-2016 | 07:18 PM
Some parts of the Harmon Creek area where a lot of boats anchor are 90 ft deep. I found the bottom there to be soft clay so my anchor just stuck to it. Anything with weight will work since you don't really need to compete with a current or high winds, you just need a lot of rode like mentioned above. I have a 28lb, navy style and I have seen the plow style like like on a cruiser windlass work well also.
NewToMe260 is offline
Old 02-22-2016 | 07:20 PM
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
I second the navy type. They're smaller, grip well and I've never had to cut the line on one and leave it behind.
Baja_342 is offline
Old 02-22-2016 | 10:22 PM
boatfreak's Avatar
Agree completly
boatfreak is offline
Old 02-23-2016 | 07:19 AM
You don't need an anchor in Harmon Creek. You will be wedged in so thigh your boat isn't going anywhere!!!!!
Mark
GETTINBYE is offline
Old 02-23-2016 | 09:51 AM
We take a disposable (Walmart anchor and line) when visiting Cumberland. Had to leave one there once.
Typically, we don't use an anchor at Cumberland, however.
ALL_IN! is offline
Old 02-23-2016 | 11:29 AM
Friend has one of those Box Anchors and 100' of line last time we were there, was in about 80' of water and held 6 boats rafted together as a thunderstorm swept overhead quickly while in Guffey Creek.. I was impressed. I will be buying one.
Gimme Fuel is offline
Old 02-23-2016 | 12:34 PM
Ing's Avatar
Ing
Veteran: Marine Corp
I don't know the waters there but I've yet to find a place where the Box Anchor doesn't hold and I've used it on rocky bottoms before. I've had mine for close to 15 years and would never go back to another style. It also folds flat and has it's own heavy duty storage bag..
Ing is offline
Old 02-23-2016 | 09:51 PM
https://www.slideanchor.com/Hlm_Shop...1-c5e749bb8688
I'm able to use the medium version .. 2 to 1 line to depth ratio also
cmattj is offline
