Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
What do you use on your Bottom? >
Old 02-23-2016 | 12:39 PM
Default What do you use on your Bottom?
I figured you get a laugh at that, Im almost done going over the boat. Now its time for the bottom, I have filled a few scratches from the trailer and lifting on and off. I hit it with 600 then 1200 and now im going to 2500 grit.. I was thinking of wheeling it with a sealer of some sort?
I know wax slows you down. What are you guys doing?
class6 is offline
Old 02-23-2016 | 01:17 PM
Too Stroked's Avatar
If you're really worried about every last tenth of a MPH, you should have left it rough - probably at the 600 grit level. Technically, the smoother the bottom, the more drag one gets. A slightly rougher bottom breaks up the bond at the surface and allows one to go just a tick faster. That said, a rougher bottom generally looks worse and makes for a real pain to clean.
As for me, I polish and wax my bottom every year. Sure, I probably give up 0.01 MPH, but the boat looks awesome.
Too Stroked is offline
Old 02-23-2016 | 01:28 PM
I do want every 1/10, but this year its going to be staying in the lake a lot more, and thought a little smoother would help and growth, that's why I was thinking sealer more than a wax
class6 is offline
Old 02-23-2016 | 02:39 PM
I should clarify. I don't use a classic Carnauba wax on mine. I use Menzerna Power Lock sealant on the whole boat including the bottom.
You will find that no wax or sealant will make much difference on marine growth though. Trust me, I work at a marina with almost 200 docks and our customers have tried just about everything.
Old 02-23-2016 | 06:35 PM
Tinkerer's Avatar
Monkey Butt Powder
Tinkerer is offline
Old 02-23-2016 | 07:08 PM
SB
Originally Posted by Tinkerer
Monkey Butt Powder
Too funny ! Was just going to reply same thing.
Life became so much better when riding my sled when I found out they make Anti Monkey Butt Powder !
One of a variety out there:
SB is offline
Old 02-23-2016 | 07:25 PM
That's Funny My nickname growing up was Monkey.. I don't know how that going to work in the water,, Should I apply it with a wheel or flip the hull upside down?
class6 is offline
Old 02-23-2016 | 07:34 PM
Tinkerer's Avatar
airless sprayer
Tinkerer is offline
Old 02-23-2016 | 07:38 PM
phragle is offline
Old 02-23-2016 | 08:01 PM
Well, I'm from the south!! Lol
[ATTACH=CONFIG]551424[/ATTACH]
nailit is offline
