Need to lower by 2 decibels ?????
You could possibly install another muffler insert. It depends on what you have now.
http://marineexhaust.ggb.ca/
i have a 30 ft eliminator daytona with twin merc 525. wet i think they are 4 inch not sure the brand of muffler boats in storage.
I use the GGB inserts (4" dia and 5.5" long, 'performance' model insert which means slightly larger internal ring diameter).....They dropped my exhaust noise by 6 dB at idle using but this was on a warmed over small block. I've found them to be non-restrictive compared to some other inserts I've used.
