Monday morn. damage report >
Old 09-23-2002 | 08:46 AM
mopower's Avatar
Toxic FORMULA
Default Monday morn. damage report
Ok , brothers and sisters , share your pain with us. Watcha break over the weekend?. Get it off your chest...maybe you'll feel better.
mopower is offline
Old 09-23-2002 | 09:04 AM
birdog's Avatar
OK.....how about this........Towed up to Erie Fri. Rain like crazy Fri.
Go to PIB Sat,Very ROUGH,Pulling into the Boardwalk for lunch and
NO steering !!! Mack had to tow me all the way back to harbor
{2 hrs. plus} spend all day & evening working on it. I was so
pissed I just put it on the trailer Sun. AM & came home
Oh well................**** happens
birdog is offline
Old 09-23-2002 | 11:34 AM
Tom's Avatar
Tom
Tried to take Airpacker out for a BatBoat ride on Sunday. Everything was running great at the dock and the trim would not go up. Fixed the trim (just the relay plug) and then the coil shorted out against itself. Now I need a new MSD box and already bought a new high vibration blaster coil. Trouble is I can't find a new MSD 6M today and he has till tomorrow or no ride cause he has to go back to Toronto. Bummer.
Tom
Tom is offline
Old 09-23-2002 | 11:56 AM
ragtop409's Avatar
Smoked the trany in my suburban. So now I got no way to get the boat to the water Charlie
ragtop409 is offline
Old 09-23-2002 | 12:26 PM
C_Spray's Avatar
Diamond Member #001
Default Short weekend (5 hours)
The port engine's been idling rough, and stalling around the docks, so Friday morning I ran the boat 20 miles over to a marina where there was a mechanic who "had some time to look at it". After doing all the electronic and computer stuff, we find a broken exhaust manifold leaking water into the two rear cylinders and putting the fire out at low engine speeds. Apparently, it would run OK at 2000+ rpm because there was more exhaust flow. Short story - had to leave the boat there while a new manifold was ordered (under warranty ), but there doesn't appear to be any damage to the engine - compression check was good. Took a $40 taxi ride to get back to our car at our home marina, though, and then a 1 1/2 hour ride home. So much for 3 days in Baltimore - we cleaned up the garage instead.
C_Spray is offline
Old 09-23-2002 | 12:30 PM
stevebaretta's Avatar
Charter Member #1015
Not too bad. Hit a small floating log. Bent prop.
Vibrated in about 20 miles. It just took awhile to
get back.
Elvis was a boater too
stevebaretta is offline
Old 09-23-2002 | 03:10 PM
OldSchool's Avatar
Default Damage Report
I think that I might have broke my liver
OldSchool is offline
Old 09-23-2002 | 04:31 PM
mopower's Avatar
Toxic FORMULA
Too much "fuel" in the liver, huh?
mopower is offline
Old 09-23-2002 | 04:43 PM
aero-offshore's Avatar
Anchored out on Muskegon lake Sat. in 8 ft water went to leave and the lower was in the sand and guess what? !@#% $%^&^%$ $#@!$%^% ^^%$#! motor ok did'nt get too hot but was there for 2 hours taking hoses off cleaning out the sand, then stupid me forgot to dicconect the bilge pump and it to was sucking sand out of the bottom of the boat!
aero-offshore is offline
Old 09-23-2002 | 04:49 PM
tmager's Avatar
My first year with a Sunsation. Turned a 102 hours for the season and the worst thing is screws in the dash and seat coming loose. Incredible, and the boat is 8 years old. I guess it helps to start the season and replace everything that looks remotely worn.
tmager is offline
