overhead crane
Old 03-04-2016 | 06:34 PM
Comanche3Six's Avatar
Default overhead crane
Here we go! Heavy material handling capability for the basement, as it's fabricated. Let's begin.
Attached Thumbnails overhead crane-20160229_122307.jpg   overhead crane-20160229_122300.jpg   overhead crane-20160229_124326.jpg
Comanche3Six is offline
Old 03-04-2016 | 07:00 PM
14 apache's Avatar
[ATTACH=CONFIG]551798[/ATTACH] This will work.
14 apache is offline
Old 03-04-2016 | 07:50 PM
No doubt!
Old 03-05-2016 | 06:50 AM
Made a call yesterday and located a piece of hollow structural steel, plus assorted new cut off scraps to fabricate mounting plates. Going for coffee, while the sun is rising along with the outside temperature. Then let the games begin.
Old 03-05-2016 | 11:33 AM
The Steel
Old 03-05-2016 | 11:41 AM
welded last night, light rust setting in, hole chamfered, sharp edges cleaned up, 36 degrees in NJ. I love it.
Attached Thumbnails overhead crane-20160305_122109.jpg   overhead crane-20160305_122145.jpg
Old 03-05-2016 | 02:25 PM
break time
Old 03-05-2016 | 03:59 PM
what are you going to lift and what is the wall thickness of that square stock?
mike tkach is offline
Old 03-05-2016 | 04:14 PM
14 apache's Avatar
Steel says 3x3x1/4 that's pretty beefy.
Old 03-05-2016 | 04:50 PM
Hey Mike
Mostly 350 to 500 lbs, occasionally more. This unit is overkill for those weights. I want to attach a 1/2 ton CM Cyclone chain hoist, but I just checked my stock and see a NIB 1/4 ton Cyclone and a NIB 1 ton Cyclone and a NIB 1 ton CM Lodestar. It's like my lottery numbers, close, but not the right ones.
To answer your question a little more in depth, this length HSS has a deflection of .358" @ 1000 lbs. I could have gotten 3 x 4 .250 wall for the same price $0. It has a deflection of .185" @ 1000 lbs but that's like shooting a rabbit with a 416 Rigby, only the ears are left.
