454 BBC Mercruiser 1978 Hawaiian >
Old 03-07-2016 | 11:19 AM
Default 454 BBC Mercruiser 1978 Hawaiian
For Sale
1978 Hawaiian Day cruiser with new engine here is what it is
It is a mark IV block(std), forged gm crank)20/20 and balanced, 9.8 pistons, factory mercruiser large oval port heads, comp cams Xtreme Marine XM278H cam and lifters(no reversion with my thru transom exhaust even partially submerged ideling at 700rpms), factory mercruiser aluminum high rise dual plane marine intake, stainless log manifold with risers that look kinda like a 2 stroke expansion chamber, bellhousing, flywheel, 10qt cast aluminum offshore winged pan and oil pump/pickup assembly, eldelbrock 750 carb, mercury thunderbolt iv ignition, and low hour coupling(A-9). Engine was put together in January and has about 30 hours on it, never exceding 4800 rpms(only for break in really) Normally run between 3000 and 3800 for best fuel economy. Engine when in the Machine shop estimates 375hp on 87 with 10* initial timing.
The Boat Has new seats for front and 2 new 19 gal fuel tanks
Call 435-893-1248 For pictures and info
$3150.00
Days away is offline
Old 03-09-2016 | 09:29 AM
Bump
Needs new rear upholstery and cooling hooked up and thru hull exhaust to finish
BEST OFFER NEED TO SELL ASAP
