Crane Cams 168741 and MEFI 4 ECM >
Old 03-07-2016 | 11:43 AM
Default Crane Cams 168741 and MEFI 4 ECM
Crane Cams 168741 Cam for Gen VI stepped nose cam $220 shipped
MEFI 4 part #12569494 ECM with a 8.1 tune in it $200 shipped
Going with a larger cam and using a MEFI 4B
roughneck427 is offline
Old 03-07-2016 | 12:31 PM
BUP
Is the MEFI 4 a stock cal and can you verify it is a good ECM - just asking
Did you convert from MEFI 3 - wondering then - do you have any wire harness or the adaption harness for the MEFI 4
BUP is offline
Old 03-07-2016 | 12:39 PM
I have not ran the ECM i can ping it on the bench with MEFI Burn if you want or unlock it. I had a MEFI 3 on my 454 and bought a whole engine harness for a MEFI 4 8.1 and im going to spin my motor to 6800 its in a Vdrive boat. I have a reluctor wheel for a crank trigger set up to use the COP ignition i went to the 4B ecm to have tuning capabilities over 6000 rpm.
Old 03-11-2016 | 08:43 PM
open to reasonable offers
Old 03-12-2016 | 03:25 PM
hammerdown500's Avatar
Are the lobes all good on the cam? How many hours on it?
hammerdown500 is offline
Old 03-12-2016 | 06:20 PM
Hours unknown but the lobes look good on it text me at 5597907580 and I'll send you some pics
Old 03-12-2016 | 11:01 PM
BUP
Was your MEFI 4 used for a Volvo Penta or Crusader 8.1 L / 496 CID app ? It would have been most likely for either one of those 2 engines is my thinking..
BUP is offline
Old 03-12-2016 | 11:41 PM
There is a paper tag tied to it that says 2004 Volvo 8.1. My bench harness from eficonnection should be here next week I can pull the calibration if needed or if this info is what you were looking for
Old 03-13-2016 | 12:20 AM
BUP
I am very familiar with OEM stock Volvo Penta and all of their ECM's plus their fuel injection set ups. I would like to be able to pull their cals from E controls ECM but I already talked to the head engineer about that one. Man they are tight lipped about everything.
So can I ask at what level or experience you have with marine ECM's ? I believe your reply with be MEFI 1 thru 4b. Just a guess on my part and just asking.
If you find time to pull them that would be great - if not no problem. Is your MEFI 4 a recal or stock tune to your knowledge ? THANKS for your time.
BUP is offline
Old 03-13-2016 | 12:32 AM
Yeah I've got familiar with MEFI burn on my person boat and some ramjet engines. I have a 1968 vdrive Flatbottom with a single plane EFI manifold and a 4150 style throttle body on it.
I have a BDM frame and pull calibrations from Bosch ecms for Duramaxs. The ktag unit I have however has a bunch of marine options and the Motorola 555 ECM is supported. I don't have one to test with though I check on eBay frequently they are pricey.
