Bravo 1 Sweptback uppers, 42 hours- Excellent condition.
I have a pair of B1 uppers that I was going to use on my current project but I am going with B1 X drives instead.
These are off a 2010 30' Baja, I believe they were behind 6.2l engines. They have 42 hours on them and are in excellent condition. 1.5 ratio. $1900 ea. If you have any questions please ask.
42 hours after rebuild?
serial #?
any damage to the case?
not really up to speed on the bravos, but 2010 standard b1 is thick floor gears and the sweptback case is a little stronger is that right?
1750. shipped to 32905 ?
just fyi, won't be able to respond on sunday
serial #?
42 original hours! There is no damage- just some minor scuffing here and there from sitting around for a while. I cannot provide the serial number until tuesday, but it is a sweptback style as shown and yes- the case is supposed to be a little stronger and have an improved clutch. Yes, these have the thick floor gears- same as the Bravo X drive- just the B1 uses a different pinion shaft. Shipping will be right around $75.00
