what is "the rail system" engine mounts >
Old 03-12-2016 | 08:16 PM
Default what is "the rail system" engine mounts
thought i seen it mentioned a time or 2 when i was doing obscure searches
guys talking about the rail system engine mounts to move the engines(s) forward and back
outonsafari is offline
Old 03-12-2016 | 08:29 PM
It's a system where aluminum angle is mounted to the stringers (if you have them) and then front and rear motor plates are fabricated and they sit on the angle, or "rails".
horsepower1 is offline
Old 03-12-2016 | 09:33 PM
wow,
where do i find them, or are they all "1 off" fabricated stuff
nice pic thanks
whats the level of difficulty concerning alignment versus front and rear offshore plates
damn i keep editing whats that under the driveshaft
jetboat
Old 03-12-2016 | 09:54 PM
wow,
nice pic thanks
jetboat
Most of this stuff is one off but not real difficult.
What you see under the drive shaft is the intake for the jet drive. Yes, that's a jet boat.
Old 03-12-2016 | 10:18 PM
very nice,
thank you
Old 03-12-2016 | 10:59 PM
BUP
Pretty sure Teague Custom Marine or possible CP Performance could get you set up
BUP is offline
Old 03-13-2016 | 09:04 AM
mainly V-drive applications, doing one on my eliminator build right now
ezstriper is offline
Old 03-13-2016 | 09:14 AM
http://www.cpperformance.com/p-16601...mount-kit.aspx
Brandonb_05 is offline
Old 03-13-2016 | 07:28 PM
Langston's Avatar
http://www.jetboatperformance.biz/pa...mount_kit.html
some stuff here to check out. its not just limited to the drag stuff ,any skater or similar cat is set up this way with some variations. but for the most part you'll be using rails with a jackshaft of some sort, stern drive or otherwise. offshore mounts are similar, with or without a midplate, but mount to the stringers in such a way to compensate for drive alighnment.
Langston is offline
Old 03-15-2016 | 09:34 AM
Correct got ours from Bob Teague
PRIMECUT is offline
