gen 5-6 thin head gaskets?
for a half a point in compression why would you spend a chunk of chanage for a cometic mls gasket to gain nothing in speed?also if your head&deck surface is not properly prepped the mls gasket won,t seal.
I have a bad habit of asking questions the answers can be found elsewhere for. ,2 GM gaskets. 14097000 .027 composite. 12555728 steel .022. I assume steel shim, not mls. For 4.25 bore gen 5-6 engines. Both in the 27-28 buck range.
