Weighted Question??
My friends and I are trying to figure out what manufacturers mean when they state in the specs how much a boat weighs. Does the weight stated by the manufacturer include the motors and drives or not?
The specs on my boat say it weighs 8400lbs. I know that you have to add for fuel, water, gear etc. But if that doesn't include the motors and drives, then it weighs a lot more than I thought.
Unless specifically stated otherwise, the reported Dry Weight will be the complete, ready-to-run weight including engines and drives.
Some manufacturers will deviate from this rule, but then 9 out of 10 times, they list both: Hull weight and Hull+Engine weight.
In your case, 8400# is reasonable for a 35 with twins.
1Boatnut
02-20-2002 09:22 PM
