what years were Gen 1 and 2 EFI's made >
Old 03-18-2016 | 02:25 AM
Default what years were Gen 1 and 2 EFI's made
Can anyone direct me to a chart that shows what gen Mercurser motor were made in what year?
I want to know about gen 1 and gen 2 454 and 502 EFI
boating4me is offline
Old 03-18-2016 | 10:07 AM
articfriends's Avatar
They had v belts vs serpentine, the plugs on ecu plugged in ends
articfriends is offline
Old 03-18-2016 | 10:08 AM
MEFI 1 was 1993-1995 ish (they may have begun earlier but I can't confirm that), MEFI 2 transitioned in 1996 for a brief period, then it was pretty much MEFI 3 and above after that.
If you have the engine serial number that is the best way to find out what it was originally designed with.
Trash is offline
Old 03-18-2016 | 10:36 AM
SB
Or is the OP asking about Mark IV, V and Gen VI ?
I'm not sure, but a possibility.
SB is offline
Old 03-18-2016 | 10:48 AM
Or vst gen 1 and cool fuel version gen 2?
buck35 is offline
Old 03-18-2016 | 11:16 AM
[QUOTE=SB;4417562]Or is the OP asking about Mark IV, V and Gen VI ?
Pretty sure thats what he meant, at one point i may have referred to mefi1 and mefi 2 motors as gen 1 and 2 which i meant mefi 1 and 2. V belt motors w vst tank and end plug ecus
Old 03-18-2016 | 01:21 PM
1993-1996 MEFI1/VST fuel system/V-belts. 1997-1997.5 MEFI1/cool fuel/v-belts.....1997.5-1998 MEFI1/Serpentine/Cool Fuel.....Either 99 or 2000 went to MEFI3/Serpentine/Cool fuel
Gimme Fuel is offline
Old 03-18-2016 | 02:20 PM
Grim? I see the different configurations you listed but I do not see which one is a Gen 1 Gen 2 Etc....
Old 03-18-2016 | 02:47 PM
Theres not really a gen 1 or 2, you may have seen me refer to them that way in other thread but i meant mef1/2 on gen v blocks w vst and usually v belt pulleys
Old 03-18-2016 | 08:54 PM
BUP
MEFI 1993 thru 95 the largest ECM - VST systems
next was
MEFI 1 medium size ECM 1996 thru 1998 and MEFI 1 software in a MEFI 2 case - Some VST systems and 1996 was the transition year for Gen cool fuel for all year models 1997.
Next
MEFI 2 - medium sized ECM - GM 1996 software in a MEFI 2 case with GM part number 16210729 the 729 is the true MEFI 2, if any other part number without the 729 its a MEFI 1 software in a MEFI 2 case. Again the only true MEFI 2 carries GM part number 16210729. This was used on 350 MAG and the L29 454 only, (the true MEFI 2).
Next
MEFI 3 very very late 1998 / for 1999, it was a smaller ECM than all past MEFI's. All MEFI 3 Gen II cool fuel
Hope this MEFI info helps whomever
BUP is offline
