Put in O2 bungs, but exhaust too wet for the sensors? >
Old 03-22-2016 | 06:28 PM
Default Put in O2 bungs, but exhaust too wet for the sensors?
I had O2 bungs put in my CMI headers and fired it up and pulled the cap and quite a bit of water was coming out. The water dumps out at the tips so the bungs are a good 16" from where the water dumps in. The headers were pressure tested and the volume of water was equal on both sides - enough to soak my hand after a few seconds.
My question is does this kill any chance of an open loop EFI? And secondary, does that seem excessive?
BBC 502 with ZZ502 cam
Excuse the loose rigging as I'm not buttoned up yet.
Baja Rooster is offline
Old 03-22-2016 | 06:41 PM
I had the SAME issue with my Eddie Marine's....
Ran it without anything in the O2 bung and water was flying all over the place in the riser...
Learned that the exhaust leak from pulling out the plug causes reversion. Put my sensor in, haven't have an issue...
Boatally Insane is offline
Old 03-22-2016 | 07:21 PM
Ah, thanks! I've heard about leaky exhaust gaskets causing reversion and now that I've seen it I'm a believer.
Old 03-22-2016 | 07:35 PM
Yea you should be ok.
indysupra is offline
Old 03-23-2016 | 12:22 AM
What he said. You should be fine.
Young Performance is offline
Old 03-23-2016 | 05:46 AM
run the engine w/ the plugs in,,then,turn engine off and pull plug,,if its dry,your good to go.
also,the exhaust can not have any leaks or it will revert,,found that out first hand.
sutphen 30 is offline
Old 03-23-2016 | 07:36 AM
after dealing with this for years, does not take much water at all to kill a heated 02, we ended up putting a bung in the header tube about 10" from flange, worked fine, understand only reading one cyl, but only way not to kill a $150 sensor..which we did 3 times in mins. also that ZZ502 cam may not be great against revision...
ezstriper is offline
Old 03-23-2016 | 08:13 PM
Ran the motor again with the plugs snugged up, checked them after, and they were dry as a bone. If anything they were way too sooty. Stupid carb, lol.
Old 03-23-2016 | 08:41 PM
On my Checkmate, I installed a Throttle Position Sensor on my carb and ran an Innovate LM-2 to datalog.. Got that carb DIALED in..
Old 03-24-2016 | 06:43 AM
stupid carb ?? what do you think a pig rich merc EFI would look like..
