External exhaust flaps
Old 03-23-2016 | 06:28 PM
Default External exhaust flaps
Anyone use Hardins stainless external exhaust flaps.Was wondering how they hold up,I ordered a set but was wondering if anyone has tried them.
pro27 is offline
Old 03-23-2016 | 06:30 PM
Search in the fountain area I think the guy with a trip 47 used them.
Wildman_grafix is offline
Old 03-23-2016 | 06:55 PM
I bought Them off the guy with the fountain this winter. I have not had any run time with them yet but I can say this. They look a million times better then the rubber ones.
[IMG][/IMG]
1989mach1 is offline
Old 03-23-2016 | 07:18 PM
Nice looks good
pro27 is offline
Old 03-23-2016 | 07:53 PM
I just added the internal flaps version from Hardin and so far I like the look
Jparanee is offline
Old 03-23-2016 | 09:22 PM
Can't really see them under my swim platform,so not really going for the look,although it is important.I am looking for something that will hold up to heat and keep water out
pro27 is offline
Old 03-24-2016 | 08:53 AM
[IMG][/IMG]
Yes, that would be me. They hold up great and look great. I removed them because I was continuing to have reversion issues with my rear engines. This was complete speculation but there was a possibility that the flappers were trapping some water due to their weight by not opening sufficiently under idle exhaust pressure. Not saying the flappers are the cause but I am trying to eliminate any and all contributing factors.
HyFive578 is offline
Old 03-24-2016 | 09:31 AM
Thanks for the reply,I shouldn't have that problem mainly looking to see how they hold up
pro27 is offline
Old 03-24-2016 | 10:15 AM
Tom A.'s Avatar
I have the rubber ones and they work great but don't look great.
My question is do the rubber o rings on the stainless ones really keep them from making a clinking noise as they bounce open and closed?
I have a few trucks at work with the stainless flappers on the stacks and all you hear when they are idling is clank, clank,clank.
Tom A. is offline
Old 03-24-2016 | 11:50 AM
VoodooRob's Avatar
[ATTACH=CONFIG]552877[/ATTACH][ATTACH=CONFIG]552878[/ATTACH] The Stainles flappers are nice quality and do not make any clanking noise. The gasket works to eliminate that. The design is an easy one bolt clamp on, BUT if you tighten the bolt too much the flappers will bind. A couple of the flappers were binding right out of the box, so I took then apart and clearanced just slightly at the moving joint. Much better looking than the rubber external flappers but also much more expensive.
Attached Thumbnails External exhaust flaps-fastech-exhaust-flappers.jpg   External exhaust flaps-fastech-flappers.jpg
VoodooRob is offline
