Air Cleaner
Now that K&N are officially approved by the coastguard I've got a question, what one to use? I got a couple motors in a boat (Kiekhaefer 482's) that has feet of clearance above the motor. Got me thinking about different air cleaners like the 9" or the 14" or a velocity stack style. Any ideas?
Have a look at this thread, with info provided I wouldn't use one
http://www.offshoreonly.com/forums/g...n-my-shop.html
I had an 8" by 2" tall on my old small block. It ran identical speeds (GPS) with or without the K&N. Choke horn milled off the Holley carb.
I'm considering another for my current build as I'm limited in verticle space. My buddy talked to one of the race teams at key west and they were running a K&N.
I'm thinking that the more area of filter media is better. Wether you get the area from more diameter or a taller element probably doesn't matter. The critical design feature is a nice radius in the base plate.
I will add this, I built and dynoed a 462 ci pontiac that made between 570-580 hp day to day, a kn 3x9 took it down to high 530s, low 540's. a 14x4 element paper or kn didnt change it enough to measure. a 3x14 cost 6-9 hp. You want as much area as possible, buy biggest one that will fit if your making over 500 hp, Smitty
