DANA LT500 Tabs/Trim Master Pump Oil >
Old 03-24-2016 | 01:36 PM
Default DANA LT500 Tabs/Trim Master Pump Oil
Anybody know what oil/fluid is used in the Trim Master Hyd. Pump that control my tabs (DANA LT500). Web search says Trimdraulic, but no longer made.
90profx is offline
Old 03-24-2016 | 02:23 PM
Revelocity's Avatar
Trim Master is no longer in business according to prior OSO posts. Insta Trim builds a pretty similar performing pump which likely uses very similar fluid if not the same fluid. See: http://www.insta-trim.com/insta-trim...dable-oil.html
Revelocity is offline
Old 03-25-2016 | 03:49 AM
Found the oil to use, thanks.
Quote from their web page:
TO BLEED
After complete installation, work tabs up and down a few times, then while in the UP position, remove filler-plug located on front of oil reservoir , allow trapped air to escape, insert plug. If unit should ever need refilling use Insta-Trim Biodegradable oil or any type of automatic transmission fluid.
90profx is offline
