2003 Velocity 260 Fuel Question >
Old 03-28-2016 | 10:10 AM
Default 2003 Velocity 260 Fuel Question
Is there a suck/push fuel pump "in the tank" on these models that supplies the boost pump ?? If by chance the answer is "yes", how the hell do you get to it if and when that time ever comes ?
90profx is offline
Old 04-01-2016 | 03:55 PM
unbolt and slide the rear bench seat forward, fuel pump access is underneath in the center.
SnailblazerSS is offline
Old 04-02-2016 | 03:36 AM
Thank you. Jarad. That's about the most ridiculous place/method. You'd think a simple access floor hatch would have been used without the seat removal, let just hope I'm not going to gave to get to it anytime soon.
90profx is offline
Old 04-02-2016 | 06:55 AM
SB
No in tank fuel pumps in most boats. Merc engine mounts all fuel pumps and accessories for that matter.
SB is offline
Old 04-02-2016 | 07:10 AM
I'm only assuming here that there is an in-tank pump only because there is nothing visible other than fuel hose from the tank going to a pre-filter then onto the block mounted boost pump pushing fuel through the Merc spin on fuel/water seperating filter. Wouldn't it seem reasonable to assume that the boost pump would not be used as the suction pump, correct ?????
90profx is offline
Old 04-02-2016 | 07:21 AM
SB
No.
SB is offline
Old 04-02-2016 | 09:10 AM
Correct, no in tank pump on your setup.
Ryan00TJ is offline
Old 04-02-2016 | 01:27 PM
There is NO in tank pump
letstalkboats is offline
