Kiekhafer kplane cable ends >
Old 03-30-2016 | 09:33 PM
Default Kiekhafer kplane cable ends
I cked all the normal sights to purchase. They are the ones that mount to the 3/16 or so shouldered stud on the tab itself. Couldn't find anything on cp or mercruiserparts. I found some that looked like they may work on cp but they were mercruiser 33c convo ends.
Tks
John
getrdunn is offline
Old 03-30-2016 | 09:37 PM
Try calling and talking to Marc at BAM.
BenPerfected is offline
Old 03-30-2016 | 09:51 PM
Will do. Would these basic ends work or are they all together different?
getrdunn is offline
Old 03-31-2016 | 01:23 AM
They are a Merc K Plane part. I got some a few years ago and they were about $12 each.
I can't find them on the new mercruiserparts site.
Griff is offline
Old 03-31-2016 | 09:26 AM
Tks
I couldn't either. I did order two different types I found on cpperformance and Hardin had some others. There is no other bracket on these that clamp cable down is there? I'm assuming the ss nut with the rubber comp where it goes the the mounting plate of the kplane/hull is it. Just seems like a long stretch.
getrdunn is offline
Old 03-31-2016 | 09:44 AM
There is a screw on sleeve for the cable. Just as it exits the rubber bushing that goes through the Cape lane almost to within 2 inches of the end of the cable threads
class6 is offline
Old 04-02-2016 | 06:28 AM
Mbam's Avatar
Offshoreonly Advertiser
I know this reply is a little late but I just saw the post. The K plane parts are here on the new site
http://www.mercruiserparts.com/trim-...nd-component-9
You can find the cable ends here
http://www.mercruiserparts.com/bam/s...ly/6614/8504/6
There are some categories that didn't make in in the conversion and I am adding them daily. In general if there is anything else you are having trouble finding send me an email or use the contact form on the site telling me what you are looking for and I will send you a link to it. Thanks for your patience as we finish getting all the bugs out of the site!!
Mbam is offline
