small block stuff. alum exhaust, dart heads perf intakes gen 1 alfa 1 transom
moving soon and if I don't make this stuff leave I will buy another boat to build and p!ss the spousal unit off worse. 2 sets dart 007 heads. nothing real special. iron 1.94 intakes 72cc chambers. 1 head has 1 bad valve guide. 2 sets GLM alum exhausts with 3 inch riser extensions. 2 performer-non rpm-intakes. 1 .040 over good to go short block. 1 nice gen 1 alpha transom assy. 1.62 or 68 gen 1 alpha drive. many alphas with good internals ugly but still keep oil in cases. several good blocks been sitting a long time. Philadelphia area. I can ship stuff. not blocks though.
100 bucks a head for the 3 good ones. 50 bucks for the needs bad guide one. 50 each intake. I am guessing about 30 bucks a head fedex ground. exhausts 350 a pair. one has 3 inch riser extenders. other pair has them removed. probly about the same to ship 1 manifold-riser, so about 60 bucks ship guess. transom assy 200 bucks. drive 200 bucks. ps pumps, alts, 25 15 ship guess. ps-alt bracket assy 25. alpha shift block with good interrupter, 50. blocks all 2 piece seal, 50 to 200. oem steel 350 crank. 20-20 needs another 10 cut for a decade of sitting. 50.
Pretty accurate pricing
.40 over running 350 short block. flat euctectic pistons. 200. .30 over with a rod went bad with another crank and pistons from twin rebuilt at the same time 100. empty standard 010 block been sitting 15 years, never hurt 50 bucks. I don't think any are 4 bolts. I have a set of 4 bolt mains for small block. 25 bucks. also 1 set of good 462624 heads 1.94 I did little practice porting on 100 pair.
