Fittings for sea strainer, where to get or just use longer hose? >
Old 04-07-2016 | 09:43 AM
Default Fittings for sea strainer, where to get or just use longer hose?
I am reinstalling my fully rebuilt 500 EFI and took the engine out time to install a house battery. To make room I moved the sea strainer. To replumb it back I could use two 1 1/4" 90 degree Hose Barbs, prefer in stainless. for a cleaner installation. I am having a hard time finding such fittinngs. Do most run longer 1 1/4" hose with sweeping bends or does these fittings exist? I would even use brass. I have only found 1 1/4 barb x 1" IPS male adapters. I would have to connect it to a 1/1/4" x 1" female adapter seems like a lot of extra fittings. Any suggestions?[ATTACH=CONFIG]553739[/ATTACH]
Attached Thumbnails Fittings for sea strainer, where to get or just use longer hose?-img_2478.jpg
janniboy is offline
Old 04-07-2016 | 09:54 AM
SB
http://www.cpperformance.com/c-1959-...-fittings.aspx
I would not use a hard 90. I would keep it sweeping. Like a full flow fuel fittings. IE: no abrupt turns.
SB is offline
Old 04-07-2016 | 09:56 AM
cigrocket's Avatar
I have purchased many of these water hose SS fittings from Teague. Check them out, they might be able to help. Lots of sizes
cigrocket is offline
Old 04-07-2016 | 10:49 AM
I think Teague can make any fitting you need in any configuration ...
HALLETT FAN is offline
Old 04-07-2016 | 10:51 AM
vintage chromoly's Avatar
Yep, Teague or CP performance. About 45 bucks each
vintage chromoly is offline
