502 ARP Head Bolts
Old 04-09-2016 | 09:06 PM
Default 502 ARP Head Bolts
Hey everyone,
Long time reader/lurker. First time posting here. I'm rebuilding my gen VI 502 and need to replace the head bolts (Had to grind off a rusted bolt to get a head off). Stock iron heads. There doesn't seem to be much info about which ARP kit is recommended for this motor. I called ARP and the tech couldn't even point me to the correct kit. Told me to "measure the stock bolts and call back". I know guys are using a specific kit that works with the 502.
I've found that the ARP 135-3601 seems to be the most common kit guys are recommending. However, apparently there are four "medium length" bolts in the ARP kit while there are only two lengths to the stock merc bolts. So...
1) Is 135-3601 the correct kit?
2) Specifically, where do the "medium length" bolts from the ARP kit go?
Thanks guys! Appreciate all the information I've found on here over the years!
RockandRoll24 is offline
Old 04-09-2016 | 09:38 PM
I have a set in the garage I pulled out of a 120 hour 575sci if your interested. Perfect condition.
wfo1 is offline
Old 04-10-2016 | 04:54 AM
I would never reuse head bolts.
Just my 2¢
Rattlesnake Jake is offline
Old 04-10-2016 | 06:16 AM
The mid length bolts go in the corners of the head under the valve covers.
Unlimited jd is offline
Old 04-10-2016 | 07:42 AM
Just my 2¢
Not saying I really disagree with you, but ARP does.
wfo1 is offline
Old 04-10-2016 | 07:49 AM
I've actually already ordered the 3601 kit. Thanks for the offer though.
Old 04-10-2016 | 07:50 AM
Thank you!
Thats what I needed to know!
Old 04-10-2016 | 09:52 AM
Just my 2¢
I reuse mine and others all the time. Many failures are on new installed parts especially with so much being imported.
getrdunn is offline
Old 04-10-2016 | 10:51 AM
seafordguy's Avatar
http://arp-bolts.com/kits/ARPkit-det...p?RecordID=357
Summit, Jegs and ARP all seemed clueless - led to a wasted weekend for me.
seafordguy is offline
Old 04-10-2016 | 02:13 PM
the head you use determines the bolts, can't believe they did know the # for std GM iron heads...but the 3601 appears to be the one for stock iron heads per summit
ezstriper is offline
