What's the original application for this filtet mount/ thermostat? >
Old 04-10-2016 | 04:06 PM
bck's Avatar
bck
Charter Member#568
Default What's the original application for this filtet mount/ thermostat?
What's the oe application ? Thanks
Attached Thumbnails What's the original application for this filtet mount/ thermostat?-imag1095_1.jpg
Straight bottoms and flat decks
bck is offline
Old 04-10-2016 | 05:25 PM
IMO that isn't OEM, it's add on. Look s like one is pressure and the other is temp.
AllDodge is offline
Old 04-10-2016 | 05:31 PM
BUP
I think that is a KE product but I would have to double check on that. CP Performance took over alot of the KE products
BUP is offline
Old 04-10-2016 | 05:55 PM
bck's Avatar
bck
Charter Member#568
It's definitely KE. I was under the impression merc used it also. Not so? It's got several ports including valve spring oiling output. It uses the 51222R filter.
bck is offline
Old 04-10-2016 | 06:53 PM
BUP
I am glad that my memory is still very good for all this marine stuff.
BUP is offline
Old 04-10-2016 | 07:26 PM
I dont believe mercury ever used that one, they had their own thermostatic filter head that was used on the HP500 thru 900sc engines
MILD THUNDER is offline
Old 04-10-2016 | 09:01 PM
bck's Avatar
bck
Charter Member#568
Ok. Thanks
bck is offline
Old 04-10-2016 | 09:18 PM
BUP
that is correct mercruiser for their OEM builds did not use that KE version
BUP is offline
Old 04-11-2016 | 05:57 PM
I don't see it on cp ?
JMPH is offline
Old 04-11-2016 | 06:10 PM
bck's Avatar
bck
Charter Member#568
I'm sure it was a KE design. Not really sure how old it is or if it's still produced. Just trying to get some background on it.
bck is offline
